If you have already checked for paper jams and followed the instructions in the documentation without success, there are a few additional steps you can try:
If none of these steps work, it may be necessary to contact Epson support for further assistance or repair options.
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
SOURCE: hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
SOURCE: ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
