Model 183825F Detachable keyboard is connected with usb port
It worked before today, (the other shoe drops, omg did it?>)
then what does detach mean.
it has wires, or what>?
USB can be wires, or bluetooth dongle, i cant see your Tablet
it has battery, time for new battery any time wireless devices like this fails.
1st things first..
2011 made pad.
Model 183825F (this is the tablet # model not keyboard)
Lenovo has zero hits on there web site for this #
but my guess, is the keyboard does not have Bluetooth USB device, ? but is just a USB keyboard.
ok found and old sales sheet in this pad
i see it came with keyboard.
runs Android OS
the only hint is see is in the spec, for docking station
it says supports wireless orig. keyboard.
so if it is wireless. detached, then the battery is dead
easy no, wireless can not run lacking POWER.
no wireless of any kind works with no battery or power supplies
SOURCE: old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
SOURCE: My computer keyboard signs are not working as
on the right on the taskbar to the left of the speaker and power symbols you should see the letters EN if not your key board is set wrong. let me know how you get on.
SOURCE: Lenovo thinkpad keeps dropping internet
This sounds like bad wiring from the internet side, or noise on the line, which would drop the connection, but not enough to indicate it. Get the line checked to make sure it's a strong, clean signal. Good luck, hope this helps.
SOURCE: Keyboard not working
For a cheap solution, have you tried plugging in a regular keyboard?
Likely, the real problem is a loose ribbon cable under the keyboard. It is a bit messy to open open a laptop. So, if you can get by with an external keyboard, it might be the best solution.
It has been a while since I opened an IBM/Lenovo. Some laptops are easier than others to replace the keyboard.
SOURCE: I had the Lenovo thinkpad SL500 sound buttons don't work
Try to use the Lenovo Care buttons this way,
Turn off the pc completely
Use the Lenovo Care button situated just right beside the power button
Press and hold it for 5 seconds
If symptom persist, please call their tech support for possible repair of your pc..
