Zanussi has several washer models with 6 KG capacity 1200 RPM spin speed specifications. You need the model number to find the manual here:
http://www.zanussi.co.uk/support/manuals/ . The model number for a front load washer is inside the door on the lower right of the opening.
For the ZWG7120P, you need to press and hold both the Temperature and the Spin buttons for 6 seconds to toggle the lock on or off. (This time is approximate.) These are the two buttons closest to the program selector dial. There is a small padlock icon in a curved line below and between the buttons. The direct link to the manual for this model in English is http://www.electrolux-ui.com//DocumentDownLoad.aspx?DocURL=2010\132\948930EN.pdf .
I hope this helps. Please add a comment with your washer model if the above child lock directions do not work on your machine.
