I don't know why it now says that the available internal memory:0M. It is supposed to have 1GB. The pictures that were in the memory were deleted and now it says there is no internal memory. It will show pictures from a thumb drive or SD card. I also tried resetting the frame and it still said there was no available internal memory.
SOURCE: Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
SOURCE: Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
SOURCE: My pandigital frame is only letting me load 85 pictures
How big our your jpg pic files?
reduce them to 800x600: sh hold about 200+ pics.
also delete the pics that were pre-loaded
fred
SOURCE: I have a SPF3410/G7 Digital Photo Frame and have
Format with fat32. Problems with filenames and block sizes. fat16 is 20 something years old.
