In short, you remove the "flange bolt".
https://www.searspartsdirect.com/model-number/917289902/0247/1509200.html
If you're looking for a step by step... there are several other components that will likely need to be removed prior. Such as mower deck, steering linkage, electric clutch, muffler, and other to numerous to mention.
Check with SearsPartsDirect.com
SOURCE: Craftsman Mower Directions
Go to searspartsdirect.com and enter your model number in the space on the right of the page. When the list of illustrations comes up click on ground drive. This will show you the correct installation of the drive belt. Or do you mean " How the Heck do you put this on?"
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
SOURCE: Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
the drive cable broke so i ordered a new one. looking for a answer on how does it connect to underside of mower and the top of mower deck ?
22'' 650 model no.917.376741. thank you.
