SOURCE: I have a Dremel model 395, type 3 that runs but
hello. yes. go to dremel.com and get new brushes for your tool.
ps kindly rate my answer as helpful. thank you. Joe
SOURCE: My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
SOURCE: flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
