Televison & Video Logo
I have a Orion SLED 4468w and the tv will come on and then it will shut off. I tried to replace the LCD main board but it still is doing, what did I do wrong?
5 Related Answers
Anonymous
  • Posted on Nov 18, 2008
SOURCE: Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Anonymous
  • 335 Answers
  • Posted on Feb 11, 2009
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail [email protected]
Anonymous
  • 4 Answers
  • Posted on Feb 15, 2009
I might be able to help... Can you send me a pic of the board?
[email protected]
marionbagget
  • 718 Answers
  • Posted on Mar 30, 2009
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Anonymous
  • Posted on Feb 06, 2011
SOURCE: I was driving down a hardpacked trail last night,
stator or magneto pully off recoil and ur gonna need to pully the flywheel off check to make sure stators back plate is intact
Last year my Orion TV it started shutting itself off after a few minutes of playing just fine. I really liked the TV. Can I fix this problem myself, or do I need to take it to someone?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1helpful
Sansui sled 3900k TV has buzzing sound when turned on then shuts off after a couple seconds. Could it be the power supply ? Maybe capacitors?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
What could cause an orion lcd model no. SLED4668W to flicker when its power on and then after a few seconds the screen goes dark but tv power stays on with sound?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
What could cause an Orion tv model no. SLED4668W to come on and then screen goes blank after a couple seconds but sound stays on?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Orion 46 inch replacement screen
You can try shop Jimmy but likely it would be cheaper to replace the set. Shopjimmy.com.
Orion SLED 1945
I have plugged in my Orion TV. It brings up a dark blue screen, no picture and will not respond to the remote that came with it or the buttons on the tv itself. I've tried all that was recommended in the troubleshooting section of the guide it came with. Any suggestions?
I have a Orion Tv and over half the time it won't
replace the main control board- might not be worth it tho, sounds like the brain is failing- more like a chip or capacitors on the main board, check for bulging capacitors and other bad visible parts
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Conwa 42" PDP Plasma TV with Orion PCBs
I have one and have been told the main board is not working.
Cant get parts. Do you want to sell your main board.
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
