SOURCE: accidently log off and cant remember password.
you wont be able to see your contact list in the new user account since this is a totally different username. If y ou cant remember your password, there is an option to click on forgot password. click that adn it will give you the option to retrieve the password. check this link as well:
https://secure.skype.com/account/password-reset-request
hope this helps
SOURCE: job has been done improperly check log files
The first thing to try is to restart the Bizhub. Power switch for that is located behind the front panel where the toner cartidges are. Not the switch to the side of the operation panel.
If that doesn't work, you need to check the job history. Press details, there will be a description of the error.
Server Connect Error: The Bizhub cannot find your computer.
Things to check:
Firewall, ports that need to be open are TCP 139, 445, UDP 137, 138
Netbois resolution not working, try using your PC's IP address instead.
If using Host Name to resolve, try Host name in uppercase.
Folder Not Found:
Check to make sure you are using the correct share name. Not necessarily would be sd.
Login error:
Need to use a Username/Password which is an active account which has priveledge for the shared directory. If on a domain, use a domain authentication string for the username ([email protected]) If on a workgroup, \\COMPUTERNAME\Username If your password rotates every 60-90 days, could be that all you need to do is update the Bizhub with that information.
SOURCE: Mavis Beacon 18 does not save users from log-in to log-in
C:\Documents and Settings\All Users\Application Data\Broderbund\Mavis Beacon Teaches Typing 16
SOURCE: how to configure odbc for multiple user in windows 2003 server
You can also try adding the datasource as a System DSN instead of a User DSN. Of course, all users on a given system will then have access.
SOURCE: web user interface timeout please log in again
This may be caused by a bus level communication problem, try a restart. Power down the computer, power down the library, power up the library, wait for the library to finish initialization and verify from the control panel it is in an online/ready state, power up the computer.
Here are two views on how to create computer administrators and administration rights
WHEN LOG IN SCREEN WILL APPER THAT TIME JUST PRESS CTRL+ALT+DEL THREE TIMES LOGIN PAGE WILL CHANGE PUT THERE
administrator and press enter if any password you put during installation of xp put that password do log in and then go to user accounts which is in control panel from there change the user rights which you want to or
right click to my computer and go to manage and then users from there also you can set rights
Here we go just press this keys ctrl+Alt+Del it will bring you a new logging dialogue box. type the user name as administrator and leave the password blank.
press enter and there you go. that means you will log into your computer as local administrator. from there go to your control panel, click on user accounts, change my account type,
from the next stage choose administrator, click change account type
hope this helps
