Question about Precor Exercise & Fitness
I am getting error on my precor 9.33, and I lost my manual, HELP !!
  • Precor Master
  • 9,489 Answers
SOURCE:
My precor elliptical keeps giving me error44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jun 26, 2014 | Precor EFX 546i Elliptical Version 4
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Error41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Jan 29, 2014 | Precor 9.21 Treadmill
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
Error 44 precor eliptical 546
Corrective Action
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
C956i Precor is displaying Error code 44 ?
Corrective Action
May 30, 2012 | Precor C956i Treadmills with HR /...
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
29 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
