Question about Pride Health & Beauty
I have a pride power chair how do I know when it is fully charged .I plug it into the joy stick and their is a green light on plus a red light on will that red light turn green when fully charged
    Top Expert:
  • Pride Master
  • 61,937 Answers
I BELIEVE THAT IS HOW IT WORKS
Posted on Mar 06, 2019
SOURCE:
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Posted on Sep 07, 2009
HoverTech
  • 232 Answers
SOURCE: How do I charge the Hoveround mpv 4? I plugged the
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Posted on Oct 01, 2010
HoverTech
  • 232 Answers
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
  • 692 Answers
SOURCE: When I turn on controller
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Posted on Apr 28, 2011
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
The power chair does not show a charging green light,although the red light is on.... Batteries???
The green light won't come on until the batteries are fully charged now if after an overnight charge you still don't have a green light then I would replace the batteries. Hope this helps you
Feb 24, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
Feb 19, 2011 | Pride New Jazzy 600 Power Wheelchair by...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
48 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
