SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
SOURCE: What type of hydraulic oil goes in a 1954 massey ferguson farm tractor
The older tractors used type TCH which meant Torque Converter Hydraulic. That's sometimes hard to find now. NAPA has a product type TDH (stands for Torque converter, Differential, Hydraulic) and is appropriate. Regarding the pink color, some of the fluids come that way. It makes leaks easier to locate. Long live old iron!
how old is the hydrualic fluid
any chance of air in the system
if fluid level is ok
will be the valve controls to control pressure and return to the arms
or operator shift stick
