SOURCE: microwave turntable won't turn
You will have to take it out and then take off the outer cover to expose the drive system for the turntable unless the items turns with the turntable removed. If it does then (and if it is belt driven) the belt may be worn and slipping. Anyway you look at it the cover has to come off to see what is happening.
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: How do you replace the lamp in a Kitchenaid
open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
SOURCE: We have a KitchenAid Superba microwave and oven
Hi, it is caused by a blown 20 amp fuse in series with the Primary door switch.
CORRECTION: Most often the first attempt is to change, or adjust, the primary door switch, but components (20 amp fuse, 15 amp fuse and cavity thermostat) in series with the primary door switch are the culprit. Check and replace as necessary the 20 amp fuse, the 15 amp fuse or the cavity thermostat.
