Refrigerators Logo
Jeff Locke Posted on Apr 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Refrigerators has a code 33 E - Samsung Refrigerators
geob91
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 128 Answers
  • Posted on Apr 10, 2018
geob91
Expert
Level 2:
Passionate:
Answers
128
Questions
0
Helped
83383
Points
414
33e is the icemaker fill tube heater error. It keeps the tube slightly warm to prevent it from freezing. You would need to remove the icemaker and there is a 1/2" or a 5/8" tube with I believe a yellow wire wrapped around it. That is the heater. Without a model# I can't be of more help
My Samsung fridge is flashing 33 E, 26 E and 8 E. I've tried holding down the top left and right buttons to reset; however, nothing happens. How can I fix this?
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
A power outage will make your Samsung fridge show the errors 1E and or SE. If this is the case, simply press the power save and lighting buttons for 10 seconds and the error will clear. OR... press the fridge and freezer buttons at the same time for 10 seconds to reset the control panel and clear the error code.Dec 10, 2016 https://removeandreplace.com/2016/12/10/samsung-refrigerator-flashing-blinking-faults-reset/
https://www.youtube.com/watch?v=4XW0fW9NjGU
Error code 33E Samsung refrigerator
What is error 33 e associated with? It refers to the heater of the water intake pipe of the ice machine. It is found in Side-by-side refrigerators.
https://all-errors.com/samsung-refrigerator-error-code-33-e/
1helpful
Samsung 33 cf french door ref. Top ice maker not making ice. Bottom ice maker ok water and crusher in door works. Reset button causes clicking sounds.
some stripped gears more than likely..
ck this site with the model #... sticker is inside the freezer or frig walls or door trim.
https://www.repairclinic.com/
not a project that you can't handle they have a helpful 800# too.
Samsung rt323ted has 33. E flashing on door after power outage and I forgot how to get rid of it. Can you help?
Samsung refrigerator giving error code 33E means the water fill tube heater for the ice maker is loose or faulty.
Pull the ice maker out and check it.
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
3helpful
2answers
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Error code 33 and 3 for modelrf261beaesp
In your owners manual,there should
be a diagnostic section, for trouble codes
They won't go away, or fix anything unplugging it
If it did, we wouldn't need these 2,000 silly motor vehicle
questions every week
2helpful
2answers
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
