ITS A PANASONIC MODEL TC-P42GT30B
Https://www.manualslib.com/manual/893822/Panasonic-Tc-P42gt30a.html
https://www.manualslib.com/manual/893822/Panasonic-Tc-P42gt30a.html?page=18#manual
Panasonic TC P42GT30A Service Manual Power Led Blinking Timing Chart
Part replacement may be necessary. May required a trained technician to perform replacement.
SOURCE: Need solution for Panasonic Plasma TV TC-50PX14
Your TV 7 blinks indicates you have a faulty ss board its bad or needs service
SS Board (SS Data Energy recovery and data driver). So check ss board for faulty components.
i think it helps
Thank you for using fixya
Chandrashekhar Bhat
SOURCE: I have a Panasonic plasma tv 2009 model TC-P46G10 that is giving a 6 blink code, any help?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Those blinks are fault indications. From the number of blinks, you can get an idea about the fault circuit part/board. If you wish to get more details, visit the site linked here. http://electronicshelponline.blogspot.com/ Blinking codes and details of many brand devices are given.
Search the site. Type in the brand name of your device in the search box at the top of the display window, to get gathered all the related posts.
