Anonymous Posted on Apr 06, 2018
How to clean the tuner on Jensen JCR-560? - Jensen Audio Players & Recorders
Marvin
Level 3:
Top Expert:
  • Jensen Master 85,242 Answers
  • Posted on Apr 06, 2018
Marvin
Jensen Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29021922
Points
266281
They make a special spray for that purpose.
3 Related Answers
Anonymous
  • 215 Answers
  • Posted on Jun 07, 2009
SOURCE: how to set radio stations in jensen JCR 280
9 times out of 10 you just have to go to the station and press and hold the number you want that station to be programmed to
Anonymous
  • Posted on Jul 09, 2010
SOURCE: Just need to know how to set the time and Alarm
the 3rd button on the first row said stop/TIME
it only works as "STOP" when the "FUNCTION" knob is on CD otherwhise is the "TIME" setting button akong with the "MINUTE" & "HOUR" buttons in the same row
coolfelix
  • 39 Answers
  • Posted on Dec 22, 2017
SOURCE: please give me link for instructions for jensen JCR-425 clock radio
To preset a channel on the JCR-425, you tune in the channel; press the "AL/MEM" button on top of the radio (at which time you will probably be switched to some other radio frequency, which is rather disconcerting), press the "Up" or "Down" button to select the desired preset channel number, press "Set" -- and only then are you returned to your desired radio station. If you want to preset several channels,
You might then think that the next time you turn on the radio that all you would have to do is press one of the 10 preset channel buttons on the front of the radio to visit one of your preset radio stations. You would be wrong. You must turn on the radio, then press the "AL/MEM" button on top of the radio. Only then can you access your preset radio stations.
You might also think that to turn on the radio you would press a button that says "Power." Wrong. You press a button that says "Radio." Well, okay. But you might think that to turn it off, you would just press the "Radio" button again. Wrong. If you have pressed the "AL/MEM" button to access your preprogrammed channels, pressing the "Radio" button simply takes you out of the "AL/MEM" function and back to the "FM" (or "AM") function, apparently taking you back to the last radio station you tuned in manually. To turn off the radio after accessing a preset channel, you must press "Radio" twice.
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
  1. Press and hold the "Time Set" button until the display flashes.
  2. Press the "Hour" and "Minute" buttons to adjust the time.
  3. Press "Time Set" again to confirm.
How to work the radeo can't get any stations
Try to put an antenna to your appliance maybe the problem is the setting or no signal receive...
You can set your player into radio mode and try to tune in or adjust the tuner to locate a good frequency signal for radio..
2helpful
2helpful
How to set radio stations in jensen JCR 280
Jensen JCR-550 manual
Get it on internet,type www.jensen.com and download the manual is free.
16helpful
2answers
NEED HELP SETTING THE TIME
i had the same issue; with a little bit of experimenting I was able to set the time. Hold down the stop/time button until it displays 12A (it might display 24H first - do it again if you don't want military time to get the 12A) Let go then press stop/time again so the time blinks. Use the hour and minute buttons to set the time appropriately. When satisfied, press the stop/time button again.
No FM Reception
So what is the question? send it back ASAP. As far as i know there are a lot of problems with Jensen CDs...
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
