SOURCE: I have samsung 1850w CM1929
if you have not plugged out the microwave...then do so now.the trick is that when you plug out the microwave it will reset the microchip.after you have plugged it out ....then you plug it back in after about an hour.if that does not work then it is time to look for a tech to repair your microwave.the problem is that the diode or the cap is bad.
