SOURCE: Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
SOURCE: Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Testimonial: "Thanks brobin, your advice was spot on and it is now working again, much appreciated"
SOURCE: water not pumping into coffee maker
Sounds like a bad pump...I would contact Keurig Customer Service if your machine is still under warranty -- they will probably send a replacement.
