Go to kitchen dot manualonline dot com. Search 'Oster 12 cup'. Note - if you take the product brand name and model, then add 'manual' and do a Google or Bing search with those parameters, you can find any manual.
Possible manual - please let us know if this is it or not.
https://www.oster.com/on/demandware.static/-/Sites-oster-Library/default/dwa69950d2/documents/instruction-manuals/OST-BVST-JBX-revB_IB-lr.pdf
SOURCE: oster coffee maker
Looks like you will have to contact Oster directly. I am unable to find replacement pots asa standalone for sale. You can contact them here:
http://www.oster.ca/consumerservice.aspx?content=contact
Or you can call them at (800) 334-0759
Canadian Residents:
(800) 667-8623
SOURCE: GE 169165 12 cup digital coffe maker
after 60 cycles it goes into the clean function, the clean light comes on..., remove the charcoal filter from the water tank, fill tank with 1/2 water and 1/2 vinegar if you want to clean it, just water if you want to get it out of clean mode..., press clean button/light for 3 seconds and clean button flashes and the cleaning process begins...It takes 60 minutes / 1 hr. to complete, light goes off when complete. reinsert filter in tank .
SOURCE: melitta mill and brew 10 cup grinder/maker
SOURCE: cuisinart 12 cup coffe maker - dc-1200
Hello sudyealf,
This is a common problem with this unit.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used an eyeglass screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
