Why is my new Hisense washing machine 7kg showing F01 how canni fix it i need assistance
My Hisense front loader does not want to open aand it has clothes inside
Hi my hisense washing keeps coming up F-06 when trying to do a washing then completely stops n does wash it can u plz help
My machine is showing E1
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
SOURCE: how to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: my whirlpool washing machine keeps saying f13
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
SOURCE: DRIVE BELT ON HOTSPOT WASHING MACHINE
my hot spot washing machine write f12 and it woud start do you have solution to this problem please
SOURCE: Error code F13 is showing
Check
the dispenser.
Check
Wire Harness connections to the dispenser motor and Central
Control Unit (CCU)
Check
Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
