The remote sensor/transmitter was knocked off the porch into the weather. the batteries still read 2.95 vdc. But no signal is transmitted to wall unit. I have reset the remot unit several times, no change. I have reset the ch on the remote several times, no change. I have reset the main wall mount unit several times, no change. there was a broken power lead on the pcb, I repaired the connection no change. What else is there for me to try to repair the remote unit? If not where can I purchase a replacement? Thanks for any help
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
SOURCE: how do I get the
Hello jdb..... The outdoor transmitter needs to undergo a wee bit of maintenance. Remove those new batteries and clean the battery contacts with the eraser on the end of a common pencil. Then replace the batteries. IF you notice that the batteries slide in easily, use a small flat blade screwdriver to gently lift the battery contacts to increase the contact when you do slide the new batteries in. Joe
Thanks for choosing Fixya!
SOURCE: skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
