SOURCE: How do I clean throttle body on 2003 Hyundai Elantra GLS?
what u do is go to your local auto supply store and buy throttlebody cleaner you remove the rubber hose from the throttle body with the engine off of course u open the throttle and spray cleaner in it then use a tooth brush inside it replace the hose done
except it will be hard to start the first time crank engine over with foot to the floor on the gas pedal do not pump it
SOURCE: where is the thermostat located in a 2005 hyundai
top radiator hose goes to engine its under that housing
SOURCE: 2003 hyundai elantra gls abs/tcs light on
unless you can discover what DTC (Diagnostic Trouble Code) has been recorded/set in the control module, it's anyone's guess.
Testimonial: "thankyou"
SOURCE: 2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
SOURCE: need fil for error code P2626 Hyundai Elantra GLS
P2626 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
I'll sure this has to do with a faulty O2 sensor. This sensor is usually
located around the header of your car, or down more on your exhaust.
Try disconnecting your battery for 30 mins, hook it back up, and start
your car again. This will erase the error. See if it comes in again.
Hope this help (remember rated this post).
