Televison & Video Logo
Gerardo Martinez Posted on Apr 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix LG 47LN5750 TV with NO picture but HAS sound?
LG 47LN5750 TV. No picture. Sound only. Flashlight test worked. See image with flashlight. This tv has no backlight inverter. How do I fix?
Larry
Level 3:
  • LG Master 5,042 Answers
  • Posted on Apr 04, 2018
Larry
LG Master
Level 3:
Answers
5042
Questions
Helped
1241639
Points
18413
This is a LED TV so there won't be an inverter board, they're only on LCD sets, what is wrong with your set is you have shorted LED lamps in the panel, its a common issue with this model TV, Ive replaced dozens of them in the last couple yrs, its not a fun job to do as the panel can be damaged very easily if extreme care isn't taken when handling it, watch some youtube vids to get an idea of how to do it...Good luck!!
5 Related Answers
Anonymous
  • 1779 Answers
  • Posted on Dec 15, 2009
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
gopakumarg43
  • 76851 Answers
  • Posted on Feb 05, 2015
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Apr 21, 2016
SOURCE: My tv has sound but no picture. Does the power supply board include the led driver?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
gopakumarg43
  • 76851 Answers
  • Posted on Nov 07, 2016
SOURCE: Have a Vizio TV: GV47L FHDTV10A. I turn on the TV, has sound but no picture. Did flashlight test & I CAN see an image when I shine the flashlight on the TV. Videos suggest an inverter slave. Any help?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
tai8247
City View TV & Computer, Inc.
  • 453 Answers
  • Posted on Aug 29, 2017
SOURCE: Toshiba 42 inch LCD with no picture but sound. Flashlight test shows image on screen. No backlight visible with power. Inverter board?
In most of the case, the LED back lights strip is out.
1helpful
2answers
1helpful
2answers
LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
3answers
LED tv LG 50LN5200 with no picture but has sound
Faulty the backlight
It is necessary to remove the panel and replace defective LEDs
Best Regards!
I have a LG 47LN5750. No picture, sound yes, I see menu when using the flashlight test and have no back lights showing. please help with my next steps in fixing this issue. Just happened this morning.
What you are describing is common in these sets. The power unit tends to cause the LED backlights to fail. It is a 50 dollar parts cost but you have to upgrade the firmware to prevent it from happening again
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
