Follow the instructions in the manual for descaling. Press the 6oz and 8oz button together for two seconds. This will dispense a cup of water(since you have already cleaned) . The clean light will flash....when the cup is done the light will go out.
That worked...thank you so much! I would have gone literally insane trying to figure this out. It took a couple of tries for me to hit both buttons simultaneously so the clean light flashed, but very easy to do. Thank you, thank you, thank you!!
You saved me too! That light was driving me crazy. After cleaning 6 times, I was thankful to find this post. Solved my issue too
Thank you so much after several attempts of descaling This worked
Great! Don't know why the manual doesn't cover this. Thank you.
The manual contains instructions for descaling the 12 cup brewer in one section and then covers descaling the single serve brewer in another section. The caveat is that there is only one clean button on the unit and it's on the side of the single brewer, so I guess you have to clean both when the clean light lights up.
This fix also did not work. Pushing booth 8, and 6 0z button at the same time for 2 seconds just dispenced an 8oz cup but did not turn the red light off
I unpluged the the coffee maker for 30 min. When I pluged it back in and the light came on when I turned the maker on. So after going through the cleanning porcess 4 times of both maker and K-cup side my clean light is still on. This coffee pot is appox 4 months old and is used once a day on the carafe side and 2 cups a day on the Kcup side. So is Cuisinart not the quality product I thought it was?
SOURCE: clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Thanks so much... it worked
No luck with this fix!
