Question about Kenmore Kitchen Ranges
Do all kenmore ovens have a thermal fuse? - Kenmore Kitchen Ranges
    Top Expert:
  • Kenmore Master
  • 28,946 Answers
As far as I am aware, no ovens have a thermal fuse. However, you live and learn, some do, but mine doesn't.
Oven Thermal Fuse (part #WP3196548 and others)- How To Replace ...
Video for Kenmore oven thermal fuse? 3:02
https://www.youtube.com/watch?v=BF-cmB9xBSk
Aug 23, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Thermal Fuse http://www.appliancepartspros.com/App... Follow these simple step-by-step ...
Kenmore Electric Range Replace Thermal Cut-Out Fuse ... - YouTube
Video for Kenmore oven thermal fuse? 5:51
https://www.youtube.com/watch?v=Ihqo1QyYwaQ
Nov 14, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the thermal cut-out fuse on Kenmore and ...
Oven Thermal Fuse - 9759242 for Whirlpool, Sears, Kenmore
https://www.amazon.com/Oven-Thermal-Fuse-9759242-Whirlpool/dp/B019S0D482
Rating: 5 - ‎1 reviewNew non resettable oven thermal fuse replaces Whirlpool, Sears, Kenmore, Estate, Roper, KitchenAid, 9759242. Replaces part numbers: AP3879224, 4452223, 1061375, AH974726, EA974726, PS974726. ... 4452223 NEW OVEN THERMAL CUT OUT SAFETY FUSE for Whirlpool and KitchenAid….
How to Replace an Oven Thermal Fuse | Repair Guide Help - Sears ...
https://www.searspartsdirect.com/...oven/how-to-replace-an-oven-thermal-fuse.html
This wall oven repair guide explains how to replace a thermal fuse. The fuse trips to protect the wall oven from excessive heating. If the fuse blows, the oven won't heat. You can reset some fuses with the press of a button; this guide explains how to replace one that can't be reset. Replace the thermal fuse using a ...
How to Replace Thermal Fuses in Kenmore Ovens | Hunker
https://www.hunker.com › ... › Home Appliances › Other Home Appliances
Nov 15, 2011 - Kenmore ovens are manufactured by Whirlpool and distributed by Sears, Kenmore's parent company. Whirlpool and Kenmore ovens have a thermal fuse that is located in the control panel of the appliance, which protects the oven control board from overheating. On Whirlpool and Kenmore ovens, it is not...
ovens have thermal fuse Google Search
Posted on Apr 04, 2018
3 Suggested Answers
SOURCE:
oldTech2332
  • 2341 Answers
SOURCE: is there a thermal fuse
No there is neither a thermal fuse or a high limit thermostat
Posted on Aug 02, 2011
shanecarr739
  • 29 Answers
SOURCE: What kind of thermal fuse is in a Kenmore C970-635121 range?
try here if this helps http://www.repairclinic.com/Shop-For-Parts/b6/Kenmore-Parts
Posted on Feb 07, 2015
My Kenmore model 950 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 28, 2014 | Kenmore Kitchen Ranges
My Kenmore model 790 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did w
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
Oven stopped working
More that likely it is in the control board. There is a possibility that there is a thermal fuse on the back of the oven that has gone out. Some Kenmore ovens were made by Whirlpool and Whirlpool put a non resetable thermal fuse in the common line to the elements. You will have to pull it out far enough to remove the back panel and find the fuse. Make sure the power is off when doing this. I hope this helps.
Feb 19, 2014 | Kenmore Ovens
Kenmore oven 9114288816
The "F3" fault indicates an open oven sensor probe or an open sensor circuit. The oven temperature sensor is no longer available. The oven temperature sensor circuit also has thermal fuse connected in a series circuit in one of the two wires in the sensor circuit. Based on the fault code, the sensor is faulty or the thermal fuse. The thermal fuse comes with the oven temperature sensor. Here is the part to order.
Oct 14, 2013 | Kitchen Ranges
No power on the kenmore 17795791
Hello there and welcome to fixya
If you have checked the circuit breaker and tried to reset it whish i highly recommend then the next thing to check is the thermal fuse with a ohm meter
the thermal fuse is connected to the control board and you can test the thermal fuse AP4423189 with a multi-meter AP3873826. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Read more: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-thermal-fuse-item-number-ap4423189.aspx?pn_=W10258275#ixzz1jq2iSX2T
Jan 18, 2012 | Kenmore Dishwashers
Thermal fuse
You can usually find an exploded view and order parts by entering your full model number here: http://www3.sears.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Microwave Ovens
Kitchen Ranges Logo
323 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
