SOURCE: Upper Spinner Falls off
rachir...I believe the manufacturer redesigned this spinner. You can find the part at this link http://www.repairclinic.com/0080.asp Catriver...post back.
SOURCE: how to use salad spinner
Just plug it and press the power on button.Make sure that you plug it in the correct power.
SOURCE: Can I purchase a replacement battery cover (snap
Check out e-bay and request exact part you need for exact model. Put a "search for" on it, somebody will get back to you. I seen lots of battery doors listed for several makes and models on someones sight when I was looking for a Kodak cable!
SOURCE: I've got mould in the little squares of my salad spinner. What's the best way to clean it?
I'm guessing that your salad spinner is made of plastic. If you don't have a dishwasher with a hot water option, I would fill your sink with very hot soapy water and let it soak until the water cools. By then, most of the mold should have come off and you can simply rinse it.
SOURCE: Is it true that it isn't good to put mushrooms in a salad spinner?
I haven't heard that but I'm guessing the myth has more to do with getting mushrooms wet. Some chefs say that if by washing mushrooms off with water, it rids them of some of their earthy flavor. Many chefs at nice resaurants simply rub the dirt off of mushrooms, not soak them.
