SOURCE: Promise SATA300 TX2 Plus PCI controller card compatibility
Southbridge shouldn't matter as that is the controller for audio.
As the supported intel chipset is listed there should be no conflicts.
SOURCE: K8T Neo Motherboard with Via and Promise SATA problems
http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
SOURCE: Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
SOURCE: lost instruction manual
KFC3100 Manual posted at
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/9705624.pdf
SOURCE: Need driver for Linksys WUSB100
Go to www.linksys.com they got every driver for their products. Make sure you get the driver for the operating system your using.
Thanks
