Computers & Internet Logo
A
Anonymous Posted on Apr 04, 2018
When Huawei TN14LSX support the PRBS test function, it should be provisioned with which client service?
Cheryl Yu
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 15 Answers
  • Posted on Apr 04, 2018
Cheryl Yu
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
15
Questions
Helped
669
Points
59
TN14LSX01 supports the PRBS the function only when the boards are provisioned with client STM-64/OC-192/OTU2/OTU2e services.
3answers
Is there anyone can tell me Can I use Huawei SCUN to deploy uplink function on Huawei MA5600T OLT
Yes, Huawei SCUN main control board has uplink ports, it can deloy uplink function in theory, but this solution is not recommend, normally 2*SCUN configured in one Huawei OLT chassis, one is active, another is standby, if active board stops working, all service can be actomatically synchronize to standby board, but since not two boards both configured uplink modules, so the uplink service will be interrupted if deploy uplink function on SCUN.
In all, Huawei GICF and Huawei X2CS are the uplink board for MA5600T. Huawei SCUN boards Thunder link com
Recently i bought a Huawei SCUN , is there anyone konw that Can I use Huawei SCUN to deploy uplink function on Huawei MA5600T OLT?
"Yes, Huawei SCUN main control board has uplink ports, it can deloy uplink function in theory, but this solution is not recommend, normally 2*SCUN configured in one Huawei OLT chassis, one is active, another is standby, if active board stops working, all service can be actomatically synchronize to standby board, but since not two boards both configured uplink modules, so the uplink service will be interrupted if deploy uplink function on SCUN.
In all, Huawei GICF and Huawei X2CS are the uplink board for MA5600T."The answer comes from a website that if you have more questions to visit their website www.thunder-link.com hopefully it will help you. Huawei MA5680T OLT Access system Thunder link com Huawei GICF Uplink Board Thunder link com
What is provisioning message? Huawei P10
OMA Provisioning Content Messages are special SMS (text) messages that contain information used to configure certain settings of a mobile phone, such as settings for the browser, MMS client or SyncML client
2answers
How to Configure the Traffic Statistics Function on S2700&S3700&S5700?
Assume that the statistics on ping packets from 10.1.1.0/24 need to be collected on the interface Ethernet0/0/1 or GigabitEthernet0/0/1. The configuration is as follows:
# Configuration the acl rule.
[HUAWEI] acl number 3333 [HUAWEI-acl-adv-3333] rule 5 permit icmp source 10.1.1.0 0.0.0.255 [HUAWEI-acl-adv-3333] quit # Configuration the traffic classifier.
[HUAWEI] traffic classifier test [HUAWEI-classifier-test] if-match acl 3333 [HUAWEI-classifier-test] quit
# Configuration the traffic behavior:
[HUAWEI] <strong>traffic behavior test</strong> [HUAWEI-behavior-test] <strong>statistic enable</strong> [HUAWEI-behavior-test] <strong>quit</strong>
# Configuration the traffic policy.
[HUAWEI] traffic policy test [HUAWEI-trafficpolicy-test] classifier test behavior test [HUAWEI-trafficpolicy-test] quit # Apply the traffic policy:
  • # Apply the traffic policy test to the S2700 or S3700. [HUAWEI] <strong>interface ethernet0/0/1</strong> [HUAWEI-Ethernet0/0/1] <strong>traffic-policy test inbound</strong>
  • # Apply the traffic policy test to the S5700. [HUAWEI] <strong>interface gigabitethernet0/0/1</strong> [HUAWEI-GigabitEthernet0/0/1] <strong>traffic-policy test inbound</strong>
After the configuration, run the display traffic policy statistics interface interface-type interface-number command to view the traffic statistics. To re-collect traffic statistics, run the reset traffic policy statistics interface interface-type interface-number command to clear existing traffic statistics first.
NOTE:
  • The S2700 or S3700 can collect statistics only on incoming packets.
  • The S5700 can collect statistics on incoming and outgoing packets, but cannot collect statistics on packets sent from its own CPU.
S5700 Switch Thunder link com
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
3answers
What is the difference between Huawei 2700 switch and 2300 switch?
Huawei S2700 target the enterprise market, S2300 target at telecom market, but most function are the same, the manufacturer did this mostly for marketing reasons as the telecom market most are big customers with better discount.
Please I want the unlocked network code of huawei y530
use this software, it very easy (use only cracked):
DC-UNLOCKER 2 Client 1.00.0460
maybe find in this page: http://gamerider24.blogspot.com/2014/08/dc-unlocker-client-final-version-download.html
this is tutorial (maybe and link):
www.youtube.com/watch?v=SsFvnBWOq6A
HUAWEI WS322 cannot connect to http://mediarouter.home
What is the Working mode ? Wi-Fi Router/Repeater/Client ?
Check to verify the DHCP setting on your home router, If it will accept new clients. Your router may have blocked un-known Mac addresses for security
http://consumer.huawei.com/in/support/products/manuals/ws322-in.htm
Top Huawei Computers & Internet Experts
Ngoro
john h
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
