Question about Leisure Pool & Spa
I have a Leisure Bay G3 pump 2 works fine but pump 1 labors and eventually quits with the breaker tripping afterward.
Could the suction and discharge lines have debris in them or is the pump shot? Also, what is the pump part number? This pump operates the waterfall.
    Top Expert:
  • Leisure Master
  • 9,906 Answers
Sounds like motor overheating if able to check amps see if 1 drawing more than 2
Posted on Apr 04, 2018
SOURCE:
koolbreezes
  • 540 Answers
SOURCE: AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Posted on Jun 09, 2008
pondking
  • 21 Answers
SOURCE: pump makes loud humming sound, does not pump,
Pull out the oil inspection plug and check oil. It is filled with mineral oil and should appear clear. If milky it would indicate faulty seals. The tsurumis are overheating often in skimmer box applications where the top of the pump is not submersed when the skimmer intake screen gets plugged. Tsurumi no longer accepts pumps for repair at their US facility. If you contact them they may refer you to a recommended rebuilder. It is a shame as we have sold hundreds of these the last 4 years and have suddenly had a rash of this similiar complaint in the last few months with little success in repairing. We have since dropped this line and replaced with Atlantic water Garden Pumps in similiar sizes.
Posted on Mar 23, 2009
SOURCE: Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Posted on Apr 19, 2009
SOURCE: rule 1800 pool cover pump trips breaker
It sounds like the pump motor has shorted. Probably time to invest in another one.
Posted on Apr 21, 2009
SOURCE: savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Posted on Jun 10, 2009
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Why doesnt my leisure bay spa get hot
This could be caused by a couple things. In order for your spa to heat your pump must be working, your heater and heater sensors must be good. If your heater is bad usually the breaker will trip. If that's not happening read below...
Does water shoot out of the jets when you press the jets 1 button? If not then you have a bad pump or the pump is air locked. The heater can't turn on if the pump does not push water through the heater. You'll know if this is happening because you'll get an error code on your control pad.
So your jets are working but no heat. This is the most common problem. Your spa has a sensor that tells the spa if it's ok to turn the heater on. That sensor is prone to failure so everything can be fine but the heater will not turn on. Get the model number off your spa pack and click the link below. Call and tell them you need a pressure switch and give them the model number. Install the new switch and you're back in action.
http://www.spapartsdepot.com/category/pressure_switches/
Mar 10, 2013 | Pool & Spa
My barracuda g3 gets stuck on the drain after working fine since I moved into the house 4 months ago. I have the main drain turned off. I recently got a new diaphram, although it worked for a couple of...
I would first try turning the drain valve off. If it quits getting stuck then maybe that is the solution. If so then maybe you can open the drain valve only slightly and it will still not get stuck. If it gets stuck even with the drain valve off then you guess is as good as mine.
I hope this helps.
Sep 14, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
No suction for pool vac
If you are not getting any suction to the vacuum, but the pump is working fine the rest of the time, start by checking all of your connections that conncets the cleaner to the filter and pump. Make sure there are no cracks, lose hoses, etc. Then, check for the following common problems with your pump that might cause low pressure in pool pumps:
1) Pump not primed
2) Leakage of air into suction system
3) Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5) Plugged basket in skimmer or hair in lint strainer
6) Dirty filter.
Sep 09, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
Mar 17, 2010 | Heating & Cooling
Pool & Spa Logo
Top Leisure Pool & Spa Experts
Kardoc
 steve
steve
Steve Slater
Are you a Leisure Pool and Spa Expert? Answer questions, earn points and help others
