When powering up the TV, there is a picture for 1 second then it goes off. The audio remains on. I have replaced the Tconn board and both inverter boards with no change.
Common issue, you have some shorted LED lamps in the panel and will need to be replaced, the LED driver section of the power supply is shutting down after a second or so because of over current, chances are its not a board issu
Testimonial: "Larry, I have an LCD TV"
Sorry, I didn't see that...do you have your 24 volts going to the inverter boards..it might vary a little from 24, I didn't pull the manual to see what your set is supposed to have but generally its 24
Since it comes on for a second something is over current or voltage and shutting down
Larry, Do I need a power supply board or a main board?
In most of the case, the LED back lights strip is out.
Hi doubles,
Power on the unit in the dark room then shine with the flashlight directly in
the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing
B+(supply voltage) coming from this board feeding the inverter board. This is
caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible
resistor.
2. Inverter board - even
the B+ is good from the power supply, if the fuse, driver transistor, driver transformer
is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
