Are you sure you have that "code" right?
Find a long list of fault codes here:
https://dishwasherguys.com/bosch-dishwasher-error-codes/
Yours is not on the list? Still sure about that number?
Ubaid
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Anthony
SOURCE: Hi, I have a Bosch
My Bosch Avantixx 6 VarioPerfect smells and therefore the washing smells.Any solutions?
SOURCE: Hi. My Bosch Avantixx 6
Hold the Start/Reload button for 6/7 seconds till the symbol disappears.
SOURCE: Bosch excell 7 varioperfect washing machine will not programme, the key flashes on the display
Dont worry your machine is ok
the flashing key means your child lock is on, and has to be disengaged
What you need to do is press and hold the on/off button for approx 5 seconds This should turn the lock off.
I hope this was useful.
