Question about NordicTrack Exercise & Fitness
I have Nordictrack Grand Pro bike and the incline will not calibrate. Also, there is backlash in the incline motor, it rocks a full 10-15 degrees?
    Problem Solver:
  • 23 Answers
The backlash or free play in the incline motor or gearing is likely making the calibration fail. I view the calibration as a "courtesy check" that the Nordic Track performs to let you know when some component is failing or has failed. It is annoying and inconvenient when it fails, but it is something like a "fix engine" light on a car. It is telling you that something needs immediate attention, likely needed to be done by a technician or repair person.
Posted on Feb 04, 2019
5 Suggested Answers
SOURCE:
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
ercupa190
  • 12223 Answers
SOURCE: I bought a second hand Proform 14.0 CE elliptical.
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Posted on Oct 24, 2013
AJIN G
  • 6694 Answers
SOURCE: Hello,my nordictrack 9800 incline trainer's incline is got stuck ,elevation not going up or down ,what is the procedure to calibrate the incline motor
If you wish to get some details about treadmill calibration and error code troubleshooting then check the following link.
http://electro-medical.blogspot.com/
Posted on Oct 03, 2016
Speed not steady, and not reading on console. Incline not working or reading.
Proform Treadmill Incline Problem Fixed How to reset re calibrate your treadmill
Please see this video for to help you to fix it in incline and calibration incline motor
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 21, 2018 | Nordic Track Exercise & Fitness
Why does my Nordic Track Reflex 4500 Pro incline automatically when I start it up?
You must tried again the s.calibration, for easy diagnose, and troubleshooting.
However you must Adjust the speed sensor, test it, clean it, and tight any plug or connector, see the diagrams attached and proceed according.
2) Lube the elevation motor, the shaft + gear, test the motor itself for open or short. see the diagram attached. If you machine use RELAIS test it for dirty, or open and repair.
God bless you
Nov 27, 2012 | Nordic Track NordicTrack Reflex 4500 Pro...
The incline does not work
1) Run the software calibration for diagnose, and troubleshooting.
2) However lube the shaft and gear very well, clean, and tight the wire connector.
3) Adjust the potentiomenter for better response. see the diagrams attached.
4) Measure the input voltage elevation motor use the VOM, see the diagram attached. God bless you
Jun 14, 2012 | Nordic Track NordicTrack A2550 PRO...
1) Run the software calibration for diagnose, and troubleshooting and fix it
2) Lube the shaft and gear, see the image, clean, and tigh the wires connector very well.
3) Adjust the potentiomenter for better quality.
4) Measure the input voltage motor, for fix it or replace. see the block and scheme. God bless you
On my nordictrack a/2350 the incline stoped working what could be wrong?
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
Dec 15, 2010 | Nordic Track NordicTrack A2350 Pro...
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
49 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
