If your 18 cubic foot Haier refrigerator is not getting electricity to the bottom fan, there could be a few different issues causing the problem. Here are a few things you can check:
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
SOURCE: 18 cu inch refrigerator ge hotpoint
my freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
SOURCE: I have an 18 cu.
Odds are great that if you clean the condenser coil (the coil under your frig) and check the Condenser fan to be sure it is running. (little fan under the frig) Bet you its one or the other..*****
SOURCE: GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
Hello friend, that's a great question!
Typically the drain pan is located at the bottom of your Frigidaire refrigerator. You can look it by removing the toe grille. Hopefully this is helpful. -Matt
