I have the orginal remote from Sanyo model: DS32225 and cannot get the closed caption "ON". It is selected and nothing comes up.
I called Sanyo yesterday and was on hold for approx 27 mins before I spoke w/a rep. he walked me thur the same procedure I did and THEN TOLD ME IT WAS MY "DISH TV" ???? Called them and CC comes from the TV. (there just "passing the buck")
********help
SOURCE: cannot turn off cc
Yes. one of those six boxes are 'setup' box.
Regards,
SOURCE: turn off close caption
It is not possible without the remote.
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS27930&brand_pn=SANYO_DS27930&mode=large&uuid=12063505821710
http://www.replacementremotes.com/store/index.cfm
SOURCE: Closed Caption won't turn off
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
SOURCE: can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
