Ovens Logo
Posted on Apr 02, 2018
My Fagor oven is showing E15 Fallo QC error and stoppes immediately
Fagor Pyro System Class A Oven stuck in in reset loop?
it sounds like you just need to have a 1-hour plus power cycle of the oven before it stops the reset loop that it's on. So after leaving it unplugged for 1 hour, you will plug it back in. However, I would use a different power source than you've initially used to eliminate that power source as the potential cause of the error that you're experiencing.
If still having issues after the oven is plugged again, please hold down the power button for at least 30 seconds before releasing it. Otherwise, you can reach out to the manufacturer for their expertise on the matter as well. Their phone number is (305) 779 0170.
Thank you.
Dec 27, 2022 • Fagor Ovens
1helpful
'In it' error on Fagor 1700X oven
That sounds like it is trying to initialize but can't.
Correct PCB ... I wonder if it is exactly the same as the old one.
Dec 30, 2021 • Ovens
How to clear E4 TG sensor for Fagor combi oven AE202
How to clear E4 error code for model AE 202
Sep 21, 2017 • Fagor Ovens
F02 on Fagor electric oven (model 5H-810X ! What the problem is ?
But the question was about F02, not F07. What is F02 error about?
Jul 26, 2013 • Ovens
2helpful
2answers
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 • Ovens
Fagor oven ht-50X
Buy a new oven, other brands not Fagor.
Apr 06, 2012 • Fagor Ovens
1helpful
I have a Fagor 5H 196X oven and whenever I set the automatic timer it cuts off after 3 seconds and the automatic shut down symbol appears does anyone have any ideas
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: [email protected]
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: [email protected].
If you have any other questions do not hesitate to contact us at: [email protected]
Best Regards,
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Top Fagor Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Fagor Oven Expert? Answer questions, earn points and help others
