SOURCE: Black and Decker Battery Charger
Fault Codes
Meaning of Fault Code
F01
Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load.
F02
Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair.
F03
Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual.
F04
Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual.
F05
Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation.
F06
Reverse Polarity
F07
Alternator Output is Out of Typical Operation Range
Operation Codes
I=I=I=I
Battery Reconditioning - (The letters DES will display for the first three seconds)
I-I-I-I
Alternator Voltage Check
OOO
Charger Standby
FUL
Battery Fully Charged
SOURCE: Black and Decker HP122 cordless drill. Battery
most likely this order: battery , charger , drill
SOURCE: Black and Decker battery charger does not work.
Black & decker chargers and bulbs for the light are JUNK..Don't waste your money on their products.I have 2 chargers for the 24 volt batts-1 is only 2 months old-It blew the fuse {soldered to the circuit board} I'm putting in a fuse holder but don't know the amp of the fuse-I'm starting with a 1 amp slo-blo and going up until it works or goes up in smoke..I had loads of problems with this B&D 3 piece set---It's only 1 year old..Total waste of money..
