Question about The Audio Players & Recorders
How to get a stuck cassette from a cassette player in car
My dad has a 1999 Buick LeSabre Limited. There is a cassette stuck in the cassette deck. Does anyone have any ideas on how to get it to eject? Will I need to remove the stereo to dismantle it?
  • The Master
  • 10,445 Answers
Posted on Apr 05, 2018
6ya staff
SOURCE:
Anonymous
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
Anonymous
SOURCE: cassette tape is stuck in
This is what I NEED is a solution to this problem---THERE IS A CASSETTE TAPE STUCK IN A CAR STERO. The cassette player will not eject the tape. Does anyone have any ANSWERS?
Posted on Sep 08, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
Anonymous
  • 19 Answers
SOURCE: jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Posted on Apr 28, 2009
proJekttaLon
Alan Timperley
  • 91 Answers
SOURCE: 1994 buick lesabre heater core removal
The heater core is located under the dash, in the center. The container holding the core looks like a black plastic box. Remove the ash tray for easier access. You may have to also remove some other covers under the dash. You must first drain the radiator then you have to disconnect the hoses. There are two hoses connected to nipples of the heater core that go thru the center of the firewall. Remove the screws that hold on the cover to the heater core. Then you should be able to get the old one out. There might be a couple of other minor steps but I'm sure you can figure them out. For re-installation just go in reverse order to put it all back together.
Posted on May 25, 2009
Error code 00 Buick century
try another mp3 player if that doest help its the raidio/ cd/ cassete unit
Jun 13, 2012 | 1999 Buick Century
What size are stock tires for this car?
1999 Buick LeSabre Custom Front and Rear Tires P205/70R15
1999 Buick LeSabre Limited Front and Rear Tires P205/70R15
1999 Buick LeSabre PP (*) Front and Rear Tires P215/60R16
(*) PP = Performance Package
Other details can find in the Buick-Lesabre-Owners-Manual
Hope helps (remember rated and comment this).
Aug 06, 2010 | 1999 Buick LeSabre
My tape is stuck in the cassette player how do i
I've done this by using a small screw driver and gently prying up on the tape while holding down the Eject button.
Jan 31, 2010 | 1997 Buick LeSabre
Programing a keyless remote for a 97 buick lesabre limited
go to "programyourremote.com" and see if they can help you with your paticular vehicle...
Jul 26, 2009 | 1999 Buick LeSabre
Wiring factory deck for iPod
yes get a new stereo unless u dont mind cuting up your wiring.
Jul 17, 2009 | 1997 Buick LeSabre
Have a cassette stuck in my 98 Buick Century Custom
sometime you can get luck by taking out the tape player and there will be a small hole somewhere on the player that you can stick a paper clip through to release the tape player. Otherwise gnetly stick a screwdriver under the tape to see if you can get it to release. no guarntees on that last one
Jan 08, 2009 | 1999 Buick Regal
Cassette tape is stuck in player-car is a 95 buick lesabre.Can you help us to get it out?
Sep 07, 2008 | Car Audio & Video
Security light stays on
First place to check would be a fuse.  See if there is one labled security or alarm.  If there is try changing that.
Aug 05, 2008 | 1999 Buick LeSabre
Sticking gas pedal on 1999 buick LeSABRE
actually my dad had the same problem with the gas pedal sticking on his low milage 1999 Buick LeSabre. As a result of this problem, he was involved in a wreck and the car was totaled. We have been told by his mechanic that this is a problem with that year of LaSabre.
Jun 14, 2008 | 1999 Buick LeSabre
433 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
stephen Kiarie
stephen Kiarie
Level 1 Expert
Roy Cunningham
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
