Adobe Acrobat 7.0 Professional Logo
Bella Harvey Posted on Apr 01, 2018
My changed missed in Acrobat
I like to use Adobe Acrobat. But several days ago I opened one of my pdf documents that I had created a week ago. And I was afraid, because all my new data for 3 days missed. Guys, please any suggestions...
  • Terry
    Terry Apr 01, 2018
    If you are using a Windows computer and not a Mac, there are several ways to recover a deleted pdf document.
    First, though, take a look at the folder named autosave in the web link below to see if there is a copy of your pdf document or not.
    https://forums.adobe.com/thread/2268295
    If not, provide more information in the comments box - for example, does the pdf document open without an error message? - you stated all new data for 3 days missing so another copy may be in a different location or can be "undeleted" from your computer.
1 Related Answer
termitheq
Aaron Burns
  • Posted on Mar 05, 2018
SOURCE: Very important data in PDF
There are only two methods that I know, which might be helpful in your hard case
https://onlinefilerepair.com/en/pdf-repair-online.html
http://www.adobepdf.repair/
1helpful
3answers
Notebook severe trouble in document
Try this out to repair pdf or just see leading instrument for hardly crashed pdf documents in the following
1. Right click on any PDF document -> Get Info
2. Click on Open with entry on the get info dialog
3. In the Application dropdown locate to your installed copy of Acrobat and select Acrobat application
4. Once you have selected Acrobat click the "Change All button below the drop down"
5. Click Continue on the user confirmation dialog
6. Quit the Get Info window
1helpful
3answers
What is pdf
PDF is a kind of file format introduced by Adobe Inc in 1993. It has the feature of non-editable and easy to share, so widely used in all over the world.
There are many tools could help us to create a PDF file, such as the famous Adobe Acrobat Pro and Nemo PDF series tool. They are both great choice for you.
I installed adobe 6 professional a few days ago on win 7 computer. but the printer drivers were not installed. i am not able to create pdf documents. also, when i try to download any pdf file from a web...
I am not 100% certain but I am not sure you can use that old a Adobe version with Win 7. The current Adobe Pro for creating .pdf files is now version 9 for Win 7. That may be part of your problem. Consult the Adobe website and see if that older version will even run in Win 7
1helpful
2answers
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
My PDF files opens with: File conversion with
You cannot open a PDF file directly in MS Word. You must first convert the PDF file into a Word file.
Of course, you can also open the PDF file in Adobe Acrobat or Acrobat Reader and then copy and paste text from it into Word.
If you have Adobe Acrobat, though (not just the free Acrobat Reader), you can open the PDF file with that program and then save that same file as a text, rtf or a Word document file (go to File, Save as, and then choose the type of file to save as), you can then open and edit in MS Word.
1helpful
3answers
Missing Resource File
Solution: Remove Adobe Reader 7.0 and reinstall it.
Remove Adobe Reader 7.0, reinstall it into the Program Files/Adobe/Acrobat 6.0 folder, then try again to create a PDF document with Acrobat Elements 6.0.
1. Remove Adobe Reader 7.0 using Add or Remove Programs, and then restart.
2. Install Adobe Reader 7.0: At the Destination Folder panel, click Change Destination Folder and select Program Files/Adobe/Acrobat 6.0. Click OK, then Next to continue the install.
Background information
Acrobat Elements 6.0 is designed to work with Acrobat Reader 6.0. In order for Adobe Reader 7.0 to work with Acrobat Elements 6.0, install both applications in the same directory. Install Acrobat Elements 6.0 first, so you can install Adobe Reader 7.0 and select Program Files/Adobe/Acrobat 6.0 folder as the destination folder.
plz follow this link for further help
4helpful
2answers
Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
2answers
Unable to create pfd with word 2007 document
That is normal, Word 2007 cannot create PDF documents, it can only save files on PDF but, being PDF non his own format, it will lose document format, and may not display pdf.
To create PDF you need the full version (not the free acrobat reader) of adobe acrobat, or a different adobe software (eg illustrator) that manages PDF.
See
Adobe Acrobat - How To Create Accessible Adobe® PDF Files Booklet
How to Create PDF Files
1helpful
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
