Hi!
Is it a portable Generator? If so we have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/Regards,
The Generator Guru Team
SOURCE: 5500 generator stopped producing eletric after
First check with the
dealer and see if it is still under warranty. If it is not, make sure nothing
is blocking the air flow around where the control modules are located. This
could cause the voltage regulator and other electronic parts to overheat. Next
check the brushes and make sure they are free of any dust or build up preventing
them from making contact.
If everything is OK the
next thing I would do is change the voltage regulator.
