Question about Nintendo Video Game Consoles & Games
When I try to go to my nintendo wii shop I keep getting error code 051030
  • Tiriaq Cowessess
    Tiriaq Cowessess Jan 06, 2019
    Hopefully you have been able to connect by now, but this would have gotten faster response if posted on the board instead of the Answers section. I must say to you, can you use this free eshop codes generator to unlock your favorite game and play wath you like for free in the Nintendo. https://nintendoeshopcodes.site/
    Master:
  • Nintendo Master
  • 350 Answers
That's an error code for wifi not being configured properly on the Wii. Check to make sure the Wii is connected to the wifi properly. Here is the support page for the Wii. How to Connect to the Internet Wii and Wii mini Nintendo Support
Here is some information on when nintendo will stop suport for the wii. Wii Shop closure announcement Nintendo Official Site
Posted on Apr 01, 2018
SOURCE:
edo333
  • 55 Answers
SOURCE: NINTENDO WII
Try this link it's nintendo's tech support:
www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Or this slightly less helpful database of errors:
www.wiierror.com/
Posted on May 06, 2008
  • 7 Answers
SOURCE: error code 209826
call tech support it should be in the manual or go to the nintendo website or look up the number online it will probably be a operating software problem.
Posted on Jun 02, 2008
  • 47 Answers
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
Posted on Jan 27, 2010
  • 1234 Answers
SOURCE: how do i get connection 24 on my wii?
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
_____________________________
Error Code: 51421 The Wii console is not able to connect to your wired router or modem.
Posted on Aug 26, 2010
  • 24 Answers
SOURCE: Accessing the Wii Shop channel to install Netflix.
051030 is a 'too busy' error, so it's probably an issue with Nintendo's servers rather than your wii.
hope it helps dont forget to rate
Posted on Jan 07, 2011
Error code 051030
Error 051030 information can be found here.
Nov 24, 2011 | Nintendo Wii Console
Wii will not connect with server. Error code: 051030
1RepairStop.com
Error Code: 051030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Aug 25, 2011 | Nintendo Wii Console
Bought a used wii and won't connect to the internet to run netflicks getting error code 051030
This is not an error with Netflix, but rather it is an error with your wireless network set-up. I have seen many people have trouble connecting the Wii to their home networks, and it does not appear to be very user-friendly. Here is the page from Nintendo's official customer support center about your error code and how to fix it.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
May 14, 2011 | Nintendo Wii Console
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
I go to the wii shop and it said error code:051030 and says cannot connect to sever.can you help me?
Hello IGWBR
You Have A Probleme With This Error : 051030
That Means :
May 02, 2011 | Nintendo Wii Console
Trying to connect Netflix on my wii and an error comes up. 051030
I just had this problem. The Wii needs an update. Go to this site and follow the instructions. Netflix should work after the update .
Apr 09, 2011 | Nintendo Wii Console
Keep getting error code 051030 unable to connect to server. we have wireless in our home which is working.
In this case all you can is try again later.
It can also be caused by interference of other wireless networks in the neighbourhood. If this is the case try changing the WLAN channel of your wii to 11, as most routers default channel is 6, this will give your fequency a bit of seperation from the other wireless connections.
Mar 07, 2011 | Nintendo Wii Console
Error code: 051030
error code 051030:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii or Nintendo DS online and test for proper response.
good luck
kc
Feb 24, 2011 | Nintendo Wii Console
Accessing the Wii Shop channel to install Netflix. Error code: 051030 (unable to connect to server) any suggestions :)?
Jan 07, 2011 | Nintendo Wii Console
Video Game Consoles & Games Logo
150 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
