Question about HTC Cell Phones
I tried to do a hard reset on an HTC phone but when I get comes up this play all it shows is like reboot and reboot to downloader it doesn't say anyting about hard factory reset
I don't know what to say the only thing it comes up the display on the HTC but it doesn't say factory data reset like most Phonezoo it just says like reboot reboot downloader like that
SOURCE:
mikechannon
  • 15 Answers
SOURCE: Hard reset for a HTC TyTn
There are two ways:
1.
Press and hold the two soft keys (the ones with dashes on) and at the same time insert the stylus in the soft reset hole. All three things need to be done together and a warning will appear. (it is a bit fiddly)
Go to Start>Settings>System (Tab)>Clear Storage (Icon)
Mike
Posted on Sep 24, 2008
SOURCE: Hard reset for a HTC Touch Diamond
I find certain voodoo rituals to do the trick. Especially those derived from rites originating in the southern gulf coast region. To start, build a low, hot burning fire pit surrounded by granitic stones roughly the size of oranges. Be sure you have a light bed of gravel beneath the fire itself to allow air space for the spirits to commune before entering the fire and your device. Use eucalyptus logs ages approximately 2 months for the fire itself, and sprinkle a solution of pulverized bat wings soaked in winter menstrual blood from a one year old goat. Wave your Diamond over the fire vigorously while chanting the names of all three major thorn gods repeatedly. That should do the trick.
Posted on Dec 07, 2008
SOURCE: How do I reset my htc 8925?
Press and hold both soft-keys [they look like minus signs] while putting a paper-clip or something in the reset hole located near the usb port.
Posted on Jan 19, 2009
  • 77 Answers
SOURCE: hard reset for htc s630
Turn it off, and hold pressed both soft key and turn it on, i will give option to hard reset. Good luck
Posted on May 08, 2009
  • 4 Answers
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is... hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S. Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure. Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
Posted on Feb 03, 2010
How do u reboot the htc one
If there's a problem with your screen or you're otherwise unable to do a factory reset via the settings menu, then you can use the hardware buttons to do a reset too. Simply turn your HTC One off, then press and hold the Volume Down and Power buttons. Continue to hold them until you enter the H Boot screen.Aug 23, 2014
How to hard reset the HTC One - AndroidPIT
https://www.androidpit.com/hard-reset-htc-one Feedback About this result
HTC One (Verizon Wireless) - Restarting HTC One (Soft reset ...
www.htc.com/us/support/htc-one-verizon-wireless/howto/394150.html
  1. Cached
  2. Similar
Restarting HTC One (Soft reset) If HTC One is running slower than normal, is unresponsive, or has an app that is not performing properly, try rebooting and see if that helps solve the problem. If the display is off, press the POWER button to turn it back on. Press and hold the POWER button, and then tap Restart.
HTC One - Resetting HTC One (Hard reset) - SETTINGS & SERVICES ...
www.htc.com/us/support/htc-one/howto/365649.html
  1. Cached
  2. Similar
Performing a factory reset from settings. Go to Settings, and then tap Backup & reset. Tap Reset phone. Tap OK.
How do reboot the htc one Google Search
Nov 08, 2016 | HTC Cell Phones
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
My htc sensation doesn't show caller name only
1. Reboot the phone
2. Clear the cache of the dialer app. Settings > Applications > Manage Applications, look for the app.
3. factory reset.
Aug 07, 2017 | Cell Phones
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
My htc went on low battery and now that i charged it the screen is black ... it just says tmobile g1 and then android and then it goes to a black screen
hi viviana escobar you can take the battery out of the phone next take the sim card out. Now put the sim card back into the phone and then the battery this should reboot your network as well as the phone. Now if after this your phone still doesn't turn on you need to a hard reset. this will wipe out all the data on your phone. To do a hard reset on your phone hold the power button and volume up and down at the same time. Next you should see a screen that should shows fast reboot erase user data. This is should help.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Oct 07, 2011 | HTC G1 Smartphone
My HTC HD2 wont start, showed error with "cprog.exe" I'v tryed soft start, tokk out batary, but now I onslu come to HTC picture when starting up,, no buttons is function..
I'm sorry, but I think you will need to contact T-Mobile for support. Call them from another phone at 1-800-T-Mobile.
If you don't care much about the info on the phone, then do a hard reset to factory defaults.
http://www.hard-reset.com/htc-hd2-leo-hard-reset.html
CAUTION - DOING A HARD RESET, YOU WILL LOSE EVERYTHING ON YOUR PHONE. REMOVE THE MEMORY CARD BEFORE DOING A HARD RESET.
Good Luck,
Mark
Apr 22, 2011 | HTC HD2 Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Continuous reboot
Could not be repaired. Was given a new phone.
Oct 15, 2008 | HTC TyTN Smartphone
Hang up
I had the same problem > HARD RESET worked. Press and hold the TALK and END buttons, and also press the RESET button [at the bottom of the phone], all of this in the same time.
Then release the RESET button but continue to press the TALK and END buttons, and a message will appear asking you if you really want to reset everything.
Nov 26, 2007 | HTC Touch P3450 Smartphone
Cell Phones Logo
35 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
