The water inlet valve has more than one connection and solenoids , I bought an lg model LRSPC2041T refrigerator , two of the four inlet hose connectors do not have a hose line. will it work like that ?
SOURCE: Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
SOURCE: Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
SOURCE: Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
SOURCE: Dishwasher LDF7920ST. Connection to water inlet leaks
if it just started the water inlet is probably defective. this can be obtained at your local hdwre. store. be carefull these oarta are brass and are really soft. pull the dish washer out and tip it up or remove it, dont try to change it where it is.
