Cameras Logo
A
Anonymous Posted on Mar 31, 2018
There is a small dark spot, which Jessop's think is on the sensor of my Fuji Finepix 660EXR compact camera andcaused by dust wind blowing in to the lens casing. Can I fix this myself and how?
5 Related Answers
Anonymous
  • Posted on Feb 19, 2008
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Anonymous
  • 74 Answers
  • Posted on Sep 07, 2008
SOURCE: Fuji Finepix S5000 ccd sensor
Send it to the Fujifilm camera repair center. The S5000 has a known issue with bad CCD sensors... Unless you want to do it yourself.
projdoc
jasbo
  • 2239 Answers
  • Posted on Dec 01, 2009
SOURCE: Tranlucent dark spot on Optoma image. Looks like
is it an optoma or an infocus? if it is the infocus, it needs to be replaced. however, to replace it, you need to remove the entire optical engine. now off of that, remove the clorwheel and clip, the main board, and the tunnel (on this model it is called an integrator rod) assembly. to get that out, remove the 3 tap screws and the large screw. once you can slide it out, remove the foil from the front, slide out the inside tunnel assembly, remove the clip, then the tunnel. because the clip is an exact fit, you cannot have anything on the tunnel that increases the size. reverse the instructions to reassemble (but you will need to replace the foil with a new one). warning: you now need to realign the tunnel using 2 of the tap screws. if you have not done this before, it is very difficult and dangerous, as you need to have the projector powered on and the screws are way inside next to the power supply. there is a risk of electrocution and damage to the projector. best bet- send it in to an authorized infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Anonymous
  • 11967 Answers
  • Posted on Dec 17, 2009
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
Anonymous
  • 11967 Answers
  • Posted on Dec 28, 2009
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
2answers
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
A mark or dark spot is appearing on all images
That's quite a spot! Yes, I believe it is on your sensor. It could be one of the following: dirt, a spot from moisture condensing on the sensor after bringing a cold camera into a warm house, or mold. It can be cleaned but I imagine it will be expensive since the camera will have to be disassembled. I don't know how much you paid for it or how long you've owned it, but if the cost will be too high, it might be time to think about a new camera. Or, you could live with it and use Photoshop Elements to remove the spot on photos you want to show off to friends.
2answers
How do i clean the sensor
You can't. What makes you think it's dirty?
1helpful
2answers
Hinge Pins
try a different store - its a common problem with this camera and larger stores might have the parts in stock it cost me $40 on the spot
2helpful
3answers
Media selection
have you tried using a different brand?
3helpful
2answers
Pentax K100D black spot on images
To clean the sensor on the K100D . . .
1) Turn the camera on.
2) Press the "Menu" button.
3) Press the right arrow to the "Set-up" tab.
4) Press the down arrow to the "Sensor Cleaning" item on list.
5) Press the right arrow & follow the on-screen instructions.
And don't touch the sensor with anything. (You will damage the sensor).
And don't blow on the sensor. (You will get your spit on the sensor).
I used one of those old rubber blow bulbs that people used to clean their lenses with before the Lens Pen came along.
Take care & Happing Imaging!
Glen
Fujifilm E510 dirty CCD
You can find the user manual at the Fuji website to download for free -
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProduct.jsp?prodcat=789907
Don't know if that is what you are after - good luck!
Color wrong and red spots
Sounds like CCD sensor problem . It starts with 'noisy' pictures ( colors not true and resolution deteriorates )but eventually the sensor stops outputting anything and you end up with blank screen. Have the sensor replaced and camera will work fine.
3answers
Dark spots in Sony W1
I think they are from condensation on the lens, or something like that. I've had them with my W1 too at times, but mostly when there is moisture in the air and I'm taking pictures of the sky.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
