SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
SOURCE: Have a Weber Genesis Silver. Gas is not flowing.
take off the grate[s] and the plate that covers the burner, find where the gas supply goes into the burner - use a compressed air source with a nozzle and blow out the burner and orifice - spiders and sometimes mud daubers love little spaces like this and will build a nest in 'em - even the slightest restriction will cause major headaches
SOURCE: Q200 weber grill getting gas flow but only at low
This sounds like a case of the OPD tank valve on the propane tank has locked
up your regulator. In which case, turn the tank OFF and disconnect the
hose from the tank. Wait 5 minutes and reconnect the hose. Now, turn the
tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is
completely open, light the burner farthest from the tank first and turn
it to the highest setting. If the flame appears to now be normal, light
the remaining burners following the same procedure. If all burners have
returned to normal height, you solved the problem. Always remember to
turn the tank valve ON VERY, VERY SLOWLY.
If the above doesn't solve the problem, you may need to replace the regulator/hose assembly, which you can purchase from any home center or hardware store that sell gas grills and accessories. Take your old one with your for comparison purposes.
SOURCE: Bought a weber genesis 320 Problem with the Weber
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
Simple solution but probably the correct answer is: Turn on the tank SLOWLY before you open any valves on the BBQ. Once the tank is on fully, close the tank and open again, slowly. Then open your BBQ valve and start as usual. The Tanks need backpressure in order to open fully. This is a safety feature to avoid opening a tank with nothing attached.
