SOURCE: 1995 camry wagon cigarette lighter not working
start with a test light and check for power at the center of the cigarette lighter socket. If power is good, then check for ground at side of lighter socket.
If no power, run wire from power wire of lighter to power wire of stereo, thus tapping the power directly and bothering to trace out where the open int he circuit may be.
SOURCE: Cigarette Lighter Pulled Out
there could be a wire in side the unit its self and that might have come dislodged
try it and let me know
SOURCE: peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
SOURCE: cig lighter, radio, etc wont work after plugging in cell phone to charge
it sounds like you blow up a fuse,check your fuse box,
check your manuel for locations
gl G
