Question about Boating
Kawasaki 23hp 726 cm what oil to use - Boating
    Top Expert:
  • Boating Master
  • 5,111 Answers
Check the owners manual. https://www.manualslib.com/
Posted on Mar 14, 2019
3 Suggested Answers
SOURCE:
  • 114 Answers
SOURCE: instruction manual for olympia cash register
you can get the manual from the below link:
pls rate me. thanks
http://www.tillservices.co.uk/acatalog/Olympia_cm_726_plus_Instruction_Manual.html
Posted on Jan 23, 2010
  • 54 Answers
SOURCE: How much oil does a Kawasaki FH680V 23HP take?
1.8 quarts
Posted on Oct 18, 2013
Starts Great cold, Will not start when hot
Usually it's the opposite lol...but this is a normal issue sometimes when too much oil is added into the oil cavity. Then what happens is the oil gets hot and thins out creeping past the piston rings, next time you go to start it, it's basically too oiled up,wet... combustion suffers.. check the oil level, spray carburetor cleaner into the plug and the carburetor if possible. Restart the mower and let it burn off the excess oil. If this until has a thermostat, double check to make sure that it's not closing off and choking out the air flow.
Oct 05, 2015 | Toro TimeCutter SS5060 50" 23HP Kawasaki...
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
I have an ex ark mower with a 23hp Kawasaki and I noticed a big oil spot up under it yesterday. So I cranked it up to see the problem and pulled it under the garage and shut it off. Jacked it up to look...
This means you have a leak that needs attention. If you do not know where it is coming from you need to take it to an expert. It's too easy to assume you know but get into an expensive job if you play with it. I know as I have been there and done that.
Nov 16, 2017 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Oil in carburetor
Make sure your air filter is clean, if it gets dirty and or plugged then it causes it to **** oil out of the crankcase through the pcv valve
Oct 06, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
How do i adj the valves on a 23hp kawasaki ?
You need to remove the rocker arm cover. Then most engines have a set screw and a locking nut that hold the valve rocker arm on. Loosen the locking nut and with a feeler gage make whatever adjustment you need (tighten or loosen) then holding the adjusting screw from turning, tighten the lock nut. It is not very hard to do and remember that they are all metric fasteners.
May 19, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Boating Logo
53 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
