When the water supply light blinks and the rinse aid light is on in a Bellini dishwasher, it indicates that the dishwasher is not receiving enough water or the water supply is interrupted. Here are a few things you can try to resolve the issue:
Check the water supply: Make sure the water supply valve is turned on and water is flowing properly to the dishwasher.
Check the water inlet valve: The water inlet valve is responsible for controlling the water flow into the dishwasher. If it is faulty, the dishwasher may not be getting enough water. You can check the valve with a multimeter to see if it is working properly.
Check the water pressure: Low water pressure can also cause this issue. Make sure the water pressure is at least 20 psi.
Clean the inlet filter: The inlet filter could be clogged and preventing water from entering the dishwasher. Clean the filter and see if it helps.
If none of these steps resolve the issue, you may need to call a technician to diagnose and fix the problem.
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
