Not sure if this will help or not:
https://manuals.appliancesonline.com.au/geh75u/geh75u-2.pdf
SOURCE: how to adjust clock? no Instruction manual!
I had the same problem... NO MANUAL.. I contacted Newworld who posted me a hard copy manual. I have scanned the manual into a PDF document. If anyone needs a copy, please email me at [email protected] and I will email you the manual. Happy Cooking
SOURCE: clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
SOURCE: Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
