Golf Logo
J
Jerry Lirette Posted on Mar 28, 2018
How remove drive shaft on a cub car golf cart?
4 Related Answers
Anonymous
  • 507 Answers
  • Posted on Oct 18, 2008
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Anonymous
  • 7 Answers
  • Posted on Aug 14, 2010
SOURCE: Taylor made driver repair
You should take it to the closest golf shop like a PGA superstore or Edwin Watts. If you live somewhere that doesnt have those resources then I would go to the local golf course next to you and ask the club pro where he would have his clubs repaired locally. Who knows, they may also do it right there at the course. It will run you a little money to replace the broken shaft, but the work and new grip will be less than $20.00. Good Luck, You may ask the person you were riding with if they pulled a prank on you with the bag falling off, Ive seen it happen. lol.
Anonymous
  • 3 Answers
  • Posted on May 15, 2012
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Bill Boyd
  • 53816 Answers
  • Posted on Mar 18, 2017
SOURCE: How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart. This is a electric golf cart
check for a broken return spring for the preal
Testimonial: "The return spring is not broken"
1995 electric golf cart. The motor runs but wheels do no move
Is this an ezgo golf cart? If it is then your brake drum is stripped. It has splines that mate with the axle shaft.
Sep 20, 2017 • Golf
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 • Golf
2helpful
Governor on my golf, I would like to remove it.
Travis, Removing governor from your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to remove governer on Club Car golf cart
How to Adjust an Go Golf Cart Governor
How to Take Governor off Club Car Gas Golf Cart
Aug 07, 2016 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
How to time cam shaft and balancer shaft
Me would leave to professionals.
try Google search with question. Or better still You Tube Sam question lots of vids might just have your reqiuuiremrnts!
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
