Question about Sony Office Equipment & Supplies
SONY VPL-DX100 PROJECTOR screen colour mixed and collected one place and blotting. What's the reason
SOURCE:
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
Posted on Jan 06, 2009
SOURCE: Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Posted on Feb 17, 2009
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Dec 04, 2015 | Sony Office Equipment & Supplies
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Jun 23, 2015 | Sony VPL-ES4 Projector
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
Jul 10, 2012 | Sony VPL-HS51A / VPL-HS60 Multimedia...
My vpl-es3 picture is not clear....showing fuzzy
is the lens focused properly.
is the DOT Phase on the input setting correct.
is there condensation on the lens.
what sort of fuzzy do you see. is it all over the whole screen. is it coloured or only one colour.
is the screen resolution matched to the video source
Mar 13, 2011 | Sony VPL-ES3 Multimedia Projector
I want to connect my Sony projector to a Humax freesat box - I am only getting a black & white picture - how do I get a colour picture
may be the Sony Projector performs the black and white functions only,So kindly get a coloured projector
Jun 20, 2010 | Sony VPL-CX75 Multimedia Projector
Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Aug 19, 2009 | Sony VPL VW10HT Multimedia Projector
Lampcover brightining
Hi there
Your Projector needs a new lamp and do remember to reset the lamp timer after replacing the lamp .
Mar 24, 2008 | Sony VPL CS4 Multimedia Projector
Hope that helps.
Mar 21, 2008 | Sony VPL CS1 Multimedia Projector
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
Aug 31, 2006 | Sony VPL-ES2 Multimedia Projector
161 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
