Question about Rio Audio Players & Recorders
My new song on my SD card won't read on Rio Sport mp3 player.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Rio Master
  • 720 Answers
I think the reason is is because the song is in the wrong format where did you get the song from was it the same place you usually get songs from and did you change the format by accident this could be the only problem that you're having
Posted on Mar 28, 2018
Testimonial: "I downloaded the music from Amazon. It's all in mp3 format."
  • Trey Hudspeth Mar 28, 2018
SOURCE:
SOURCE: SD card in MP3 player
Was the SD card in the MP3 player when you loaded the songs or did you load them some other way?  You may have to first put the SD card in the MP3 player first, then load the songs onto the player.
Posted on Oct 17, 2007
patel352003
  • 192 Answers
SOURCE: micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Posted on Jan 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Need down load for Rio Sport S30s MP3
Check out this website for the software that came with the Rio Sport device (clcik on the software tab - depending on your Windows version, you may need to also select the drivers tab aftwerward):
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=212
-Tha Mp3 Doctor
Posted on Feb 04, 2008
SOURCE: Problem with SD card recognition
Try updating the firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it off, remove the battery and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
Posted on Mar 05, 2008
Which audio files for sd cards?
see what type of sd card is in it and if it is less than 4gigs of memory that should reduce loading time for booting it up,and as far as audio files just try mp3 see if that helped
Apr 01, 2012 | Rio Cali Sport MP3 Player
Sd card wont let player turn on,works without it but not with it
that's means its not compatible together. Try to get another SD card that would be compatible.
Take care
Feb 04, 2010 | Rio Forge Sport Digital Media Player
Forge not recognizing SD Card
the socket where card is installed may have internal loose element so its not detecting.check out the card in another device and also check another card in your device.this will confirm the fault.
Mar 06, 2009 | Rio Forge Sport Digital Media Player
Won't Process a Playlist
Had problem when on the expansion SD card not being able to add playlists, found out playlist are only saved in main memory, so I had to remove a song from main memory to add another playlist.
Aug 12, 2008 | Rio Cali Sport MP3 Player
Rio Cali
Your friend probably wanted to blame you for breaking her already broken mp3 player and you didn't figure that out until now.
May 10, 2008 | Rio Cali Sport MP3 Player
SD card = too big for player to read. Get a smaller SD card.
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
-Tha Mp3 Doctor
Nov 24, 2007 | Rio Sport S35S MP3 Player
Using an external memory card
you should format the Sd card by the software from rio, and I am using 1g SDcard ,I am not sure if 2g sd card works fine.
Jul 31, 2007 | Rio Sport S35S MP3 Player
Memory card
Had the same problem with 64MB, but was able to use store music on 32MB and 256MB SD cards.
Oct 22, 2006 | Rio Chiba Street MP3 Player
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
